I had a 10 spline SM465/ NP205, when the seal between the two failed, the t case would over fill while the transmission would go low. And that is without any pressure pump like an auto.Not as likely as the other way, the 205 isn’t under pressure like the trans is
How did they auto lock, was it a switch, button?The syncro version of the 205 was used in the auto locking hub trucks to make shifting on the fly easier and at high speeds….I guess they figured if you didn’t have to stop to turn the hubs in you wernt going to stop to put it in 4wd
