handloader90
Building!
What about your vacuum advance for the dizzy.
Your trans requires constant vac to up shift correctly.
Some egr vac ports will zero at idle and also reduced with the throttle open and tend to be larger.
Make sure you have manifold vac at idle and full vac with the throttle open
The Holley I have has the vac advance port which is hooked to the vac advance om the dizzy. A 3/8" port on the passenger side which the brakes are hooked to (I want to route my pcv vac line there) and it has a small vac port on the base plate under the front metering block, roughly the same diameter as the th350 vac hard line.
