Woo Hoo! Few days away
I had quite the surprise when I went out to inspect my truck this past weekend. Apparently, the fuel pressure with the truck off, was enough to push gas through the secondaries on my carb down into the cylinders and then seep into the oil
My oil was full of gas, and created leaks in the oil pan, dip stick tube, and rear main seal. I got all three of those replaced, and it seems to be holding. I also readjusted the carb to prevent it from happening again.
So, as it stands today, I am in!
I am going to bring camping gear, and if the weather is decent, camping sounds like a great idea. If the weather is
not-so-decent then I'll probably be heading back to my house and can accomidate a few people if need be.
Charles, I was planning to stop by your place today or tomorrow to pick up that Q-Jet from you ..... you gonna be around?
Thomas.
-- '84 1-Ton Blazer --
When the goin' gets tough,
the tough go
1-Ton
