Started taking this thing apart over a year ago and now finally have the parts and gumption to put it back together.
Hopefully this thread will be running about 2 weeks and then I'll be done. If you don't like dumb questions, go ahead and hit your browser's back button. I've searched and read enough that I think I can get it right, but thinks are always a little different when you put a wrench on a bolt for the first time and I'd like a little affirmation. Specs are 4" RC all spring lift kit + 2" blocks to acommodate the camper sag and 3/4 ton axle conversion on a 76 K5 Chalet.
On lift springs - the shim points towards the front right? Thinking about, it makes sense but it doesn't say in the instructions. I searched "pointy end" but didn't come up with anything.
Rear shackle bolt - I put a new bushing in the rear shackle and torqued it to 45#'s. Then bolted the front of the spring, put a floor jack under it to flex it out, and then bolted the rear to the shackle. Torqued those to 120#'s. Is the rear shackle supposed to pivot? I'd think it would, but just verifying. I'll probably double nut the shackle bolt because it seems like moving back and forth like that the it would eventually loosen itself.
I thought it was stock.
