Changing hubs.....
gokartergo
3/4 ton status
Hollister, CA
How hard is it to change hubs? I have a 86 with the auto hubs. I havn't had any problems yet . But I have heard the stories about automatictly engaging when in 2wd and automaticly disengaging when in 4wd. I got a set of warn hubs for xmas. But I don't now how much work is involved.. Thanks
Gokartergo
It is not hard. You will need a torx socket to remove auto hubs.You will also need allen wrenchs, snap ring pliers and I use 2 small flat blade screwdrivers to get out the large snapring.
That's it! You don't even have to jack up the truck to change 'em. How's that for an easy upgrade?
<font color=black>HarryH3 - '75 K5</font color=black>
<A target="_blank" HREF=http://ThunderTruck.ColoradoK5.com>http://ThunderTruck.ColoradoK5.com</A>
Enjoy it while you can!
I think everything turns into a larger job! On my hubs we ended up having to go back to the parts place because one of the hubs was defective. Turned 30 min. job into 2 day job, cause wasn't able to get back to the store the same day!
'86 Military Blazer <font color=green><A target="_blank" HREF=http://www.geocities.com/m1009_86>http://www.geocities.com/m1009_86</A></font color=green>
