clark 455 5speed / eaton 4005a 5speed ?
sweetk30
Back to play nice .
in the back of your brain
I have the top cover off my trans to reseal it . I never drove this truck ( blown engine other thread ) so I don't know if it was noise .
the reverse gear is kind of floppy on the shaft ? ?
is this normal or is it going south and ready to drop ?
the rest of the inside is super clean . oil drained was dark and no major chunks or bits . drain plug mag has normal super fine junk on it .
I did notice the 1st/rev shift fork has more wear than should . prob from someone riding the shifter when driving . I was planning on checking price for new .
any help would be great .
here is the parts blow up http://r.search.yahoo.com/_ylt=AwrBT...QzlGRTpELo.W8-
Clean oil tells me a lot about the internal conditions aside from the wear that you noticed
Did the bearing under the reverse gear look like it had a lot of wear? Maybe that particular component has a high clearance ( which would not surprise me considering the application)
did not take it apart . just the top cover is off. and I was wiggling stuff and poking around and noticed the gear had wobble.
