original balzer
Hey enough yappin about colors and show us some finished pics!
Hey enough yappin about colors and show us some finished pics!![]()
Or maybe someday I'll meet you in Nebraska instead, we'll split the drive time...someday i'll drive out to ohio and we can take side by side pictures.![]()
OR. I could photoshop our rigs together. That might be easier.![]()
So who has built his own steering brace? I don't want to fork out the coin for ORD's kit, and it looks fairly simple anyway. Anyone have ideas on how to build one? Got pics of what you've done? Do you wish it were beefier? How?
I built my own brace, just based it off ORD's used some tube I had laying around and some scrap plate. I put some lenghts of tube about an inch and a half long on the back 2 bolts, then a longer "spacer" to a hole in the cross member then just did a trial and error sort of thing to get a piece of 1/4 inch plate I had laying around to span the three bolts. I think I did the same sort of thing for the front top bolt as ORD does as well, can't remember though its been quite some time. And no I don't have pictures, I can grab some when I go home for spring break, its going to be a while thoughSo who has built his own steering brace? I don't want to fork out the coin for ORD's kit, and it looks fairly simple anyway. Anyone have ideas on how to build one? Got pics of what you've done? Do you wish it were beefier? How?
Yep it's Lime Green, I have the mall-crawler version of Colby's rig that's painted the same color.
BE CAREFUL! They are not for SHOW for a few more years!
Looks like you're gaining a LOT of clearance under the tank with this setup!
Well, it just goes to that central hole in the front crossmember there and the two rear bolts for the steering box. Just gotta get the angles and lengths right. Bit more to it than that but the basics are there.
If you search I put some pictures up and ranted a bit when I did mine a year or so ago.
i'll be building this over spring break, along with a small list of other projects - so when you go on break, it would be great if you could snap some pics. this is on the bottom of my spring break list, so i'll probably start on it later in the week, which should give you some time to lieserly get the pic!I built my own brace, just based it off ORD's used some tube I had laying around and some scrap plate.
mine was kind of out there, mainly just to spread the load on the frame and tie it into the crossmember
I think I will be heading home on the 27th for a long weekend so I can snap a quick picture for you then. Its not much to look at if I remember right, I built it when I was first learning to weldi'll be building this over spring break, along with a small list of other projects - so when you go on break, it would be great if you could snap some pics. this is on the bottom of my spring break list, so i'll probably start on it later in the week, which should give you some time to lieserly get the pic!
Well, i'm trying to finish up the structural components of my fuel tank tunnel today. had a little surprise tho. i was working with the grinder and had it kick back in a way i've not dealt with before.
i almost cut off my wang.
it kicked back into my coveralls at wang height. i fortunately was wearing slightly baggy cover alls and the blade wound up in the fabric and stopped the motor instead of slicing through to Private Stephens or the Great God of Testiclese.
Progress pictures of the tunnel later today.![]()
