hoodride
yikes!
Next step is to go to the auto parts store and pick up a radiator hose with a nice tight 90* bend in it to route the fuel filler neck. I'm going to have it pop up and out of the back of the box on the right upper corner. It will have enough help from gravity to get the fuel into the tank, but should still be short and sleek enough to not get in the way of cargo too much.
I think its cheaper than that. I bought a couple feet from my local Napa store. I think it was around $10 a footDo not use radiator hose it is not intended for gas or diesel, and will deteriorate over time and cause problems. They tend to dry up and crack\leak. Fuel filler hose is going to be somewhat expensive thou, If I remember $20 a foot.
i went in and they steered me in the right direction (thank goodness i spoke with a parts guy who knew something about vehicles!). it would've been $20/foot for the fuel hose, which i can't afford right now, so I decided to use some left over tubing from the cage and have a nice tight 90* on it, so I'll use that and adapt everything around what i've got.Do not use radiator hose it is not intended for gas or diesel, and will deteriorate over time and cause problems. They tend to dry up and crack\leak. Fuel filler hose is going to be somewhat expensive thou, If I remember $20 a foot.
Are you are incorporating the mounts into your bumper where the load will transfer into both frame rails?
I would add a piece on each side of the frame plates to create a thickness similar to the shackle opening. I don't like the shackle to shift side to side in the hole.
huh?
anytime. shoot me an email via ck5 (click on my username to the left of this post and click "send e-mail to") and we'll hook up.that thing looks really nice i live in medford and would like to take a look at your k5 sometime
