It's been a while! I've recently moved to Southern Oregon and going to school has slowed down my progress significantly....
Current plans for the truck are as follows:
1. I'm going to re-do my current
cage to frame mount system and give myself an inch body lift or so in the process. The cage/body is hard mounted to the frame, so I'm going to put a spacer between the body and the frame and then reweld the cage/frame mounts. I'm going to add a few more mounting points as well.
Included in this will be extending the sliders over the wheel wells w/ some round tubing and connecting to bumpers. The over-the-wheel-well tubes will have some tubes going to the frame. This should give me a good place to build shock hoop mounts in the future...
2. I have been mulling over
fuel tank options. I think what I've decided on is to cut the floor out of the rear of the blazer, raise the existing fuel tank up until it's at least flush with the frame rails and then built a removable tunnel over the top of the tank so that the cargo space can continue to be functional. Thoughts? Ideas? I've seen them in the bed or under the bed, but not so many pics of part way thru it like I'm imagining. Anyone have pics of something like this?
3. I am going to replace all of my
guages as well, and build a new guage pod. What types of considerations should I take when looking at guages? What makes one brand better than another? I'll be doing a mechanical oil and a mechanical temp. guage...
4. I have a
York and a tank, so that'll be getting put on in the near future for OBA as well. I think I'll mount the tank under the rear seat like in the tech article. I'd like to put a pressure guage in the cab of the truck, tho, instead of in the engine compartment like in the tech article.
Ofcourse, this all takes time and money... so lots of time! Hopefully I can get most of it done by summer so that I can hit McGrew Trail and the Rubicon this summer!
