I stumbled across this today. I don't know if it's a legitimate option, but I think it's a cool rig.
http://premiumandexotic.com/premium/?p=4074
Are you planning on DDing the new rig? I was thinking you would only be using it sporadically. If you really are planning on putting 20k miles on it every year, the math changes.
And once you start calculating fuel costs for a rig you drive regularly, common sense takes over and you wind up with a Saturn and a 6.2 truck.![]()
I put 9000 miles on the beetle in July and August. Every weekend I drive 400 miles. They add up quick.
Even sporadic trips can be 800-1000 miles at a time.
I still don't get it when people post up this reason. A fuel filter for my Cummins Dodges is under $15, I think the fuel filter for my 7.3 PSD trucks is even cheaper than that.
IIRC, the LS and big blocks hold 6 quarts. My diesels hold 12. I go nearly twice the mileage in my diesels as I do with the gas stuff. Yes, a diesel's oil filter does cost a few dollars more, it's bigger. Factory air boxes are nearly identical between gas and diesel in the same chassis so the air filter is a wash.
If someone utilizes proper mileage out of their diesel's oil change instead of dumping good oil at 3-4K, there is little extra cost on the diesel side. At least a small enough difference it's not even worth a consideration when purchasing a vehicle.
Yeah, 400-mile weekend trips add up quick, that's exactly what caused me to buy my little car. But I didn't realize you planned to use the tow rig for those trips, I thought that you'd just leave the trail truck up North and that you'd only be towing during the summertime cross-country trips.
If you're towing every weekend, efficiency is probably king.
I really like the duramax Quigley from a few pages back with only 15k on it.
Was that the one that was too expensive?
Yea, but in the long term it might be alright. The largest issue is that it's in Washington...
Fly out and drive it back?
Haha yea... I know I could. I'd need a 3 day weekend or Thanksgiving break.
That would be a loooooooong trip.
Sounds like something that we would do.![]()
I've driven back from Seattle in 3 days. It's a haul.
