Coolant level keeps disappearing and not leaking?
I'd suspect the radiator long before the water pump, especially if the engine stays cool with no load.
It could still be a headgasket even if its not overheating all the time, blown headgaskets do mysterious things sometimes. You can get a little testing kit that has you mix some coolant from the radiator in a vile with a solution and turns a certain color if you have a blown headgasket. Its really easy to do and not very expensive.
Thanks for all the help. I actually got the truck towed home for free so I can work on it over my Christmas break. I am pulling the heads and sending them out, valve job, seals, valve rollers need installed, and all that good stuff. I will check it first, but thats my plan and it seems to be a bad head gasket. I will check the radiator out too. I wonder if the guy who I bought it off of put some stop leak in it and I never knew it. He was a crook anyways, I wouldn't be surprised. I will figure it all out this week and after Christmas. Thanks again for all the advice. This truck knocked about 10 years off my lifespan. Here is a link of her getting towed. http://www.cardomain.com/ride/2402491/4
Figured out what it was....
One blown head gasket and the other was cracked and also had valve damage and a cracked head. Got the new head for 50 bucks and had both heads drilled out 30 thousandths over so I did not have to get the new guides tapped out. Oversized valve stems and a boil and shave should do it. There was stop leak in there too so I think somone before me knew about it! That bonehead. Got the gaskets and seals and valve rollers and it should be done soon (second week in January)
2 blown head gaskets but I found 'stop a leak' in there. He must have put some in before I bought it and failed to tell me. Anyways, extensive valve damage and a cracked head. New head and oversized valves installed and positive end seals. The truck runs great now! put about 250 miles on it so far and its a champ. Better fuel milage too. Terrible around town but double digits on the highway. Just hard to start in this cold PA weather. Thanks for all the help! Take care
