newer 60s are b/j style and can any one say poped b/j asap from the stress!!!!!
Desert Rat said:I have a couple of questions, many derived from the above comments:
1. Will these boxes be pretty much for trailered rigs or can they take the highway? Top recommended speeds?
2. With 8 inches of lift, if a rig kept the stock front springs, would it have clearance problems or would you have to use at least 2 inches of spring lift as well or is the 4 inch drop the solution to that problem?
3. Is this a completely custom design or a spin off of other proven portal axles?
4. It is hard to see, but it looks like your setup replaces the knuckles, but retains the original inner C's?
5. For a front D60, would you be adding extra bracing, perhaps even an over the top brace similar to Missouri Offroad or is the extra stress on the axle tubes not that severe?
6. I mapped your shop address and you are out of town a bit. But not so far as to be inaccessible from my neck of the woods. Is your shop open to the public, or do you strictly take online orders and ship from there?
Very kewl too see you answering us Chevy guys questions. I think these portals are a awesum idea. I'd like too see them under a full size K5 Blazer. Real coman axle swap for the K5 is a 14 bolt FF rear, and a Dana 60 front. What about breaks ?? Are they disc breaks front and rear ?? I really don't know jack about these things, but think it's awesum. Love the ground clearence. How big of a tire can they handle on a full size rig like the K5 or even a burb ??tkojeep said:These boxes were not designed for this vehicle. We are currently fabricating a buggy that will have a link suspension for these boxes.
How ever we are designing a new box that will bolt onto a D44 or D60 front and almost any rear axle with a 4" drop and 1.5:1 gear ratio.
If you guys have any questions post up and I will reply asap.
~Kirk
