pennsylvaniaboy
Just curious Kert, what is the intended goal of this truck?
OK, Kert.... I'd like to get your measurements, how wide did you space the tubes out? I'm thinking the tubes on the bed should be further apart so one has better footing and won't slip off and skin his/her shin. Similar to the DPI trailriders model.... if you could space the tubes out like that then it'll work for me. I'm not sure how well that will look on a SRW truck though....
I know it's a one off design and not in production, but I'm almost convinced to order a set and I'd like to know if they are a bolt on affair, instead of welding to the sheetmetal.
Well, the stantion tubes are 3.5" from corner of the rect. tube to inside of the slider tube. So overall, they'd be 4.375" out from the rect. tube.
The ones you see here are welded on to the sheet metal.
It's my tow rig.
haha this is a great quote....this will be one of the stoutest, heaviest, capable, etc....tow rigs ive seen. i mena diff covers, beadlocks, sliders etc. dang![]()
That sure is a beefy lookin cart they got there.![]()
Knowing first hand the BEEF that Kert builds, They may have had to upgrade their cart to hold up.
LOL He musta had a project for them in the past that crushd the cart!
I have to admit Kert I am concerned about the weather/mud affecting the actuators. Have you done anything in veiw of that? Maybe as simple as a splash sheild? Are you using weather proof/resistant conectors? Im sure you have already thought about all this, but Im curious.
weatherpak connectors are gold for making water dirt tight connections
