Cross-over on First Gen Blazer - Engine Crossmember issues?
Engineered Vintage
IGOR
Vendor
Damascus, OR
Is the engine crossmember going to be an issue on this rig?
I know some have problems on the '73 up - but ours are in a different spot...
/forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif
Thanks for the long-winded answer! /forums/images/graemlins/rotfl.gif
[ QUOTE ]
[/ QUOTE ]
[ QUOTE ]
[/ QUOTE ]
....and thank YOU for the double-post! /forums/images/graemlins/thumb.gif
Seriously, it works fine. Even a straight draglink won't hit the crossmember on our trucks.... plenty of pics in my .sig
Greg is exactly right (as usual /forums/images/graemlins/thumb.gif). I have been scoping out the clearance I'll need to do crossover and there is PLENTY of room. Piece o' cake!! /forums/images/graemlins/thumb.gif
Here's mine. Only problem I see is that with a 4" lift the drop pitman arm is kinda close to the leaf spring. Gotta get the 42's and 8" leafs /forums/images/graemlins/laugh.gif
http://www.florida4x4.com/tech/d60cross/index.php
Very slick - I took the steering shaft out of a newer 73 up 2wd drive - hoping that will work - it looks like it will be a direct swap with the 4x4 one... /forums/images/graemlins/thumb.gif
