I
mine and also cut the bushwackers........................
while i'm at it i think i'll make room for 38 boggers
I had bushwackers on my old K5, they are good for a street truck...but they do not play well with trees, rocks, or any other hard object. not to mention they are tad fragile during the winter months.4trolls said:I cut mine and just left them ,now I'm starting to regret it . I kinda want my truck nice now
BigCountryx said:Has anyone done this to make the edges cleaner, as in so it won't cut my 2 yr. old if she's playing around my truck.
it is hard to put it down,
away. your tires will thank you. just ask mine.
Anyhow I run a 3" TC lift and 37" MT/R's and no rubbing.
o well it was something to talk abouthey jason: does your friend have 3/4 ton axles and how about the rim size. i want to be able to bring my tires more under my k4 as they stick out too far with what i've got right now. mine is 14 bolt rear 3/4 outers up front. 6 inch lift with fenders cut. rims on now are 15x14 with 39.5x18x15 boggers. thanks in advance.jaysonsk5 said:i run a 4" with zero rates pushed out in front with a 3" body lift and rub alittle on the fire wall at full stuff and lock. i can live with it, not alot of rocks in iowa.
this might be a little much for you but my buddy runs a 6" with 39.5" tsls. he trimmed verry little, not a wheeling rig, but it's his D.D. however he is running 4 1/2" backspace on his rims.
Hijacking a two year old thread.......
