Cylinder heads
So I have my son in laws uncle that I know can rebuild engines. And my brothers buddy that says he knows how to rebuild engines and has done a lot. My dilemma is my son in laws uncle isn’t very reliable as far as when he can teach me how to rebuild engines. He also said to bring to machine shop first! Which is ok with me. My brothers friend said to just pull engine and no need to bring to machine shop and he will teach me how to rebuild but I might need to order tools. I’m debating because my cylinder heads, crankshaft, push rods, timing chain etc… are all brand new and I’m scared to ruin everything and lose a lot of money. What do u all think I should do? Pay machine shop to rebuild or just have machine shop do minimum and hope friend teaches me correctly?
I would have your engine checked by someone who knows what they are doing.
If it needs machining definitely have it done but I agree that the grunt work you should do especially if you have help.
If you were closer I could help.
I might still take a day and come over and help once you have all the parts and the machine work is done.
If you were doing a budget build, I would say skip the machine shop but you are putting a lot of money on the parts do it right and have a machine shop treat the engine to a spa day
Ya I think I will just have the machine shop rebuild the engine, then I will just drop it back in and re-install everything. Thanks
Assembling an engine isn't that difficult.
Measurements and parts prep are key, as is cleanliness.
If you were going to have to buy specialty tools to assemble your engine, you can use that money for the machine shop. Have them do the long block, leave pan and timing cover off. We will guide you from there.
You should really degree cam, and decide weather timing should advanced straight up or retarded.
Those tools can be spendy. Dergreing and setting a cam is a skill many do not understand, but make a difference in ok running engine and outstanding.
So I got engine out and took to the machine shop, after discussing with the owner about the rebuild I ended up buying a 383 stroker from him. He had it built already for someone who ended up going a different route. They just need to install the cam and cylinder heads and a few things. Should have it back in a week or so.
It’s mandatory that ya give us some cam specs when going with a stroker motor.
so been doing some research on breaking in the cam and doesn’t seem too complicated, as long as I get the truck to fire up right away and keep engine at 2500 rpm and fluctuate to 2000 rpm here and there for about 20 min should be good right? Also I will try and get someone to help so can make sure no leaks or anything.
The concern isn’t if you’ll do a good job breaking it in, it’s that the flat tappet cam failure rate these days is sky high
Why no roller cam?
Because most oils all took the zinc out.
You have to do good oil research and use one that still has it. Even conventional ones took it out, so you either but the right oil, or add a zinc additive.
Oh and also bought the cylinder heads that need flat tappet cam. The shop did tell me that I needed zddp oil.
I will call them tomorrow, I don’t think he has installed anything yet. I’m assuming I can return everything, I bought from summit recently
Nah. Watch the Motor oil geek. You can break these in on vr1 or driven without additives
Go roller and avoid the drama
