Ok, if you have not done this yet, we need to go back to basics. Get someone to follow you, preferably with two people in the chase car.
Get it to the bounce speed, and let them come alongside and see what it actually happening.
It probably would help if you watched while they drove too.
Sometimes actually seeing the problem will give you a clue. It might not be the wheel you think, even though is seems it has to be.
If its for sure that wheel, then you need to do the wheel bearings. I suggest that if you do not find anything wrong with them, pull the other side and swap as much stuff as you can left to right.
Unless the antibiotic is still dumbing me down, you should be able to swap the hub, drum or disk, wheel and tire.
If the problem moves, then it is some part of what you swapped. If not, then its in the suspension, or the spindle is loose.........
That is a good idea. Maybe i will con mike into helping me with this tommorow.
It's worked before...
I fixed my wobble, on the rocks...
So, we still on fer tomoro?
And heck yes. lets wheel up a storm
