MetalMulishaMarcus
1 Ton Status
I think if you look hard enough you'll see there are calipers that'll bolt up to 1/2 or 3/4 ton 4x4s that had slightly different piston sizes..
They may use the same pad and mounting bolts patterns,but they are different..
I had a customer who bought two rebuilt calipers and new hoses,and immediately had a "pulling to one side when I hit the brakes" issue..
It took a lot of investigating before he finally decided to blame the calipers--we measured the pistons and one was about 3/16" larger..
I got another caliper off the shelf and found it had the same sized piston as the one with the larger piston,he swapped the matching pair on and no more pulling issues..
The catalogs listed one part # for several years on half tons,but somewhere in the late 70's they added a 3/4 ton caliper with the larger pistons to the listings....the guys truck was a frankenstein made of spare parts from several donors ,so it was always "fun" to find him the right parts whenever he came in to buy something..
It's good to know, I'm gonna have to check to see exactly what I have on the rear of my truck then. I'm sure they are 1/2 ton calipers but not sure anymore now.
