Dana 60 Must haves
What's this?
Does this replace the seal that goes on the stub shaft and rides against the back of the spindle? OMG I've wasted many a bearings with water getting in that way.
inner axle seal new style . keeps the oil in the diff . and dosnt care if your axle has a grove worn in it from years of spinning on a seal .
For clarity sake, what is the oem application and spicer part number?
Spicer is usually cheaper than national around here.
How new and is it straight forward to install? I will probably have a shop put it in when my gears change. Got me curious sir.
What's this?
No but the trailgear bushing posted earlier does, and I'm thinking the same thing haha, how did I miss this was available!!
longfield inner spindle bushing kit over the needle bearing stuff . but as said lots of these upgrades are hardcore or just do it once and be done type of thing .
Has anyone used these before? Im just curious if they wear out fast or not. Do they hold the axle snugger(my bearings dont fit my axles very tight and allows movement)
there is or was a test video of there bushing with a axle spinning in it no real lube on it for a long time with no major wear after the test . and also the axle was NOT square to the bushing for this test to show how good they are .
I've been running them for about 5 years now. Way better than the needle bearings and I didn't see any wear on them last time I had it apart. I use an extremely high temperature/pressure grease on it, my Yukon locking hubs, and Yukon U-joints. (they have spinning parts without bearings) @rdn2blazer recommended it and works great
https://www.summitracing.com/parts/aaf-all78246/overview/
