Dana 70 disc conversion... Pricing added.
clarkjw24 said:
Have you had a chance to slide a dually rim over them yet?
Nope, haven't gotten that done yet. I'm pretty sure its gona hit though.
Well let me know if it will work. I've got 2 duallys running D70s and I really would like to add disk to them.
x2 I use my rig to pull heavy loads, and I want better stopping power--that's why I asked about the dual caliper and/or D60 caliper designs.
Thanks, Jimbo
Are y'all using the Dana 70 HD?
I'm gona see if I can't fit them up this weekend to a dually rim. Gotta finish the axle up anyway so it can be gotten out of the way.
I have the 70 HD also, and plan to fit H1 rims so I'm interested to see how the dually setup works for you.
How's that looking?
OnetonCowboy said:
How's that looking?
Still haven't gotten to it! Been totally swamped the last week or so. Get to it soon as possible. Sorry for the wait.
Alright guys, it will work with h1 rims
Looks as though we will be adding an D70HD kit to the website. Gotta get some measurements first.
alright so i just want to confirm for the 1000th time, this will work on a d70 dually axle right? ive found a dually axle, and want to convert to disc and run h1's on it. will these brackets be able to use the caddy calipers? thanks kert. if so, ill be making an order for all my stuff from you first week in may :)
We are working on an HD specific kit. The only hold up is the diameter of the neck down area for the weld on flange. Once that measurement is secured we're ready to go. They will clear H1 wheels so that's a go there.
My brother measured his dana 70 HD today, now unfortunatly the digital caliper would not go over the tube completely so this measurement may not be 100% correct, but the main tube was 4" and necked down was 3.5".
Whatever your caliper bracket was, it slide perfect over the necked down part of the axle
BUMP for more installed images, I'm putting mine together this weekend
I don't have the larger opening rotors so I have to figure that out...
5.375" I.d. If memory serves.
Not sure if this ever was cleared up, There is a HD specific kit to fit on the Dually axle however, the brake caliper will NOT clear a dually wheel. So, the HD kit is only good for those converting to a different hub and running Single rear wheels.
More to come on the dually wheel disc conversion.
