Dana 70 disc conversion... Pricing added.
does anyone happen to know if the D70 HD kit will work on a 14 bolt dually axle? I have the wide dually version, and gonna run srw hubs, and stock H1s. the axle isn't at my house, so I can't get a measurement right now...but I was thinking it might be 3.5" also. anyone know for sure?
As best I can recall, the area where the flange welds on was the same dia on both my D70HD and '76 14 bolt. I don't know if the later dually 14 bolts are the same but I'd bet they are.
sweet, that's what I was hoping. I just know the bolt on kit won't work because of the width, so I have to use a weld on style. I think there's other companies that make weld on versions for the 14 bolt...but I like this one the best by far. so I'm hoping it will work, but wasn't sure, since it only lists is as being for a D70.
Your best get would be to get all your measurements together, call and talk to Kert. That way you're both on the same page about what you are doing and with what axle.
Brett
