Daughters 01 24 valve Dodge
Not worth it. The parts I had to buy to fix it was only 80.00 bucks, For handles and key cylinderers.
The plastic on the column I have spares of. So lucky that way but still pissed off!
I thought it looked like there was door damage from forced entry?
Your right both doors are focked.
They were like that when we got the truck. Not the first time it’s been raped. :doah:
Trucks been hard starting after sitting again.
When we got it it was hard starting after sitting. I replaced the injector tube o rings that fixed it till now.
Noticed the return lines at the T are leaking. Ah that will fix it!
Spent way more time than it should have to replace the rubber grommets on the three lines. Blood and swearing plus dropping tools down between the block and starter made it special.
Still starts slow. :doah:
I’ll check the fittings again for tightness. And then see if I can get to the banjo bolt for the return line at the back of the head and change out the crush washers for it.
Apparently if you lay on top of the engine and stuff you head against the windshield while you have both arms around each side of the head you can kind of get at it. Tomorrows fun I guess.
That rear banjo is all by feel and a pain in the butt to get lined up.
I’m sure you’ve thought of this but hard starting is usually a sign of a dying injection pump.
