Destroyed my 89 Jimmy
Wildman III
Registered Member
Garner,NC
Well mothers day I went wheeling while my wife was taking a nap .
I found a huge hole and buried my jimmy . water and sand entered through a weak front crank seal and wiped all the engine bearing and crank out :(
5 hours later and 2 toyotas to pull me out here are the pic's
Well I trades my 69 vw for a 85 K5 with a 540 BBC and tons . with a 4 inch lift and 35's :D. Now I will take the 89 and build a trail rig :saweet:
she was dreaming against your Jimmy....:mad: BUT it's a chance to UPGRADE:D:D
There is a silver lining to every cloud. Like others have stated, now is the time to upgrade and rebuild. You will be happy when your done. :D
It has a 540 BBC putting out 748 HP 850 FTLBS of toqure
with a 14 bolt and a 10 bolt 8 lug front
TH400 trans with a np208 case
cam lift around 630 very chopy
4inch lift and 35's
carb is a 850cfm dual feed double pump mechanical secondary's
hydroboost brakes dietroit locker in the rear open in the front
geared 4.88
4inch lift and 35's
geared 4.88
wow that's some serious power...i feel sorry for that 10 bolt front....
4inch lift and 35's
geared 4.88
Want to give it away? :D
numbers but I
It doesn't have STS's either, Thats a great upgrade
Any vids of it running ?
Well I used it after work to pull some trees up on the side of the house :haha:
I think my wife got a vid of it .
It is a completely diffrent k5 I still have the other one but I am making this one my tow rig
