Detroit slop
It sounds like excessive backlash in the ring and pinion to me instead the Detroit locker. The Detroit will make quite a sound if there is excessive backlash when it locks in.
New R&P, when i felt the driveshaft slop of 1/3 of a turn i thought the same thing. Damn! I blew the backlash adj. Pulled out the indicator and checked. .008
? ? ? The 1/3 driveshaft turn was before it started to turn the R&P
Then i saw that it's common on the Eaton faq page
I am guessing the slop has to be between the axle splines and the Detroit carrier then.
I'm going to check next time it's apart. When i drop the pan for the fluid change I'll do some testing and update
Not that worried, but while i have it open gonna check out what i can.
I'm assuming SL means soft locker. Seems like a good option, Centex is having good luck with it
Being a 30+ yr Journeyman Toolmaker, i sometimes find myself not being able to stop trying to figure out how things work/tick
Constantly have to remind myself
" You're not building the space shuttle, send it"
"Look at what Roadkill gets away with!"
:pimp:
I agree, just send it.
While having a locker has it's tradeoffs on the street, once you get it in the dirt it's like magic.
Add a front Locker and you'll feel like you're driving a tank, almost unstoppable.
Drove mine in the snow storm in February. No issues with going around corners or anything even on snow covered ice. It was a lot of fun being able to just whack the throttle while going straight and have the rear end walk out and drift as long as I wanted.
Had the same type of improvement with the Spartans. It's like nite and day.
Won't be without at least 1 locker again
As long as I am easy on the throttle no issues with the Detroit and I coast thru corners, It does lock and unlock at times but not excessively harsh or noisy. But having a general lack of horsepower and 4.10 gears make it less obvious, I am sure if I had more horses and/or lower gears it might make more noise and lock up more. Been running it for 15 years with zero issues.
For the record, you can see where the slop in a Detroit comes from. Zoom in on the center of this locker, the gaps between the square teeth on the axle gears and body are cause (not the r&p or splines). It’s inherent to the design.
By now it’s a moot point but… run it.
Yes, there has to be some pre-determened clearance between the square cut teeth so that the locker can lock and un-lock to differentiate, or it would never unlock.
I know this but the subject was about the yoke slop and that is the main source.
Yes and turning the yoke till the r&p play PLUS the detroit play AND the axle shaft play in the side gears all get tight 1 direction or the other will give your input yoke a LOT of play over other units / designs .
What he said...
