Oh yah for sure. Ill rip it down next weekend. Ill try a leak down check just to be safe. But I think the only way to see the gremlin inside is to get a peak at #7 with the head off.
hang tough brudda.. I know it's a huge huge letdown after the effort.. trust me, I get that... but in the end, the rig will be much more killer... just something you couldn't foresee...
Time to put those Patriots on....
I said the same thing on FacebookTime to put those Patriots on....
Yah, if it is just a gasket and not the block or something, I may see what a shop will charge to assemble and deck those patriot heads. I think they would need steam holes drilled too.
I'd do some digging man. You've still got time if it's something simple like an intake or head gasket, which hopefully it is. If I was closer, I'd all for helping get this figured out, hell, I even have all the gaskets in my tool box.
good attitude.... you'll have your chance... I know it's a tough pill to swallow.. but life has those moments... and you'll win in the end...![]()
I mean you could always run it by every time you do a circle around the dunes, pop the radiator cap off and drive into the lake. Endless supply of water
Thanks guys. I'm pretty bummed, but as I like to say.....You gotta pay to play.
Idk if I want all that sealer running through my nice radiator, I'll just tear it down and see what's happening. If the block is intact I'll probably see about getting those aluminum heads on.
I guess now I need some good links on how to's of engine work lol.
I have arp head studs, can those be reused? Or do I need new?
Way to do it the right way![]()
