I got the disc brake swap almost done on my 14 bolt FF, just need to plumb it. I have a skyjacker line coming down to the pumpkin I just need to go out from there. Can I get the parts I need from Napa or do I need to order some custom stuff? Any part numbers. I found some numbers but they didnt pan out to much.
Also Can I use a 1310 to 1350 U-joint conversion On the stock driveshaft to connect to the 14 bolt?
The Chevette lines are popular; on one truck I got soft lines with the kit, and on the other I just reused the original front lines and looped them a bit.
I found the part number from DR's post. It looks like Napa part number 20996 Rubber brake hose will do the trick. However part number 7818 Fitting for rubber hose to hard line comes up as a radiator hose on Napa's site.
If you try it make sure you get a good double flare tool. The one I bought was useless. I ended up borrowing a Rigid one from a guy at work that was better, but still not great (in my hands anyway
I just bought a new Imperial double flaring tool from Sears. It is made in the good ol USA.
