This is where i got my rear flex lines for the caliper end of things. http://www.tsmmfg.com/Brake_Accessories_others.htm#FLEXIBLE BRAKE HOSES
If you're running early calipers with the 7/16" banjo bolt you want this hose...
[FONT=trebuchet ms, Arial, Helvetica]3703-8 $50.00 pair [/FONT][FONT=trebuchet ms, Arial, Helvetica]BRAIDED STLS [/FONT][FONT=trebuchet ms, Arial, Helvetica]8" [/FONT][FONT=trebuchet ms, Arial, Helvetica]AN - 3 3/8 - 24 [/FONT][FONT=trebuchet ms, Arial, Helvetica]7/16 - 20 [/FONT]
If you're running later calipers with the 10mm banjo bolt you want this hose...
[FONT=trebuchet ms, Arial, Helvetica]3702-8 $50.00 pair [/FONT][FONT=trebuchet ms, Arial, Helvetica]BRAIDED STLS [/FONT][FONT=trebuchet ms, Arial, Helvetica]8" [/FONT][FONT=trebuchet ms, Arial, Helvetica]AN - 3 3/8 - 24 [/FONT][FONT=trebuchet ms, Arial, Helvetica]M10 X 1.5[/FONT]
It's on my list. My biggest problem problem with the cheap (and to a lesser extent the Rigid) flare tools was also that the would flare off-center. I must have practiced 10 times on scrap tube using all kinds of different tricks with both tools before I did the final flares. I tried lube/no lube, chamfer inside/outside/both, and slightly different lengths of tube sticking out of the tool. They all came out pretty much the same.
These are the chevette lines. Thanks in advance for any info
