I partially disagree. I believe there is going to be some upwards force on the springs because the axle is rotating, not trying to slide laterally.Greg72 said:Kert,
I understand conceptually what you're getting at, but there are a couple of things to consider....
1. The springs in your drawing would be a lot thicker and more substantial than what you've shown.....ie. stiffer. And the forces aren't pushing the spring UP...they are moving laterally, trying to compress the distance between the spring eye and the springpad.
I think the springs can still warp because of the rear shackle allowing the sping to move, as Kert shows in his drawing.
I think that ntsqd's design would greatly decrease axle wrap, but not eliminate it to the extent the standard design does. Given enough torque, wrap will still occur. I think that is why miniwally pointed out the most successful single link designs he's seen have the link coming off the bottom of the axle. That would help inhibit the actual axle rotation.
I'm not an expert, but I am a thinking man...
