DO NOT OPEN IN PUBLIC, YOU WILL BECOME INSTANTLY ERECT!!!
Started messing with some cage design ideas since we were a little (very) slow at work today. Here is what I came up with so far. Input and suggestions are appreciated.
The black bars in the side view shot are part of the C pillar bracing and behind-the-seat cross bar supports. I am going to have to kick the cross bar backwards from the C pillar upright to clear the seat. The seat angles back enough where the shock mount tube goes is below the headrests of the rear bench so I can't just bring bracing straight up to the C pillar in the same plane as the C pillar hoop.
The dashed line tubes in these sketches are optional but would be all or none. I would prefer to not use them if possible since I think they would reduce headroom above the front and rear bench seats but I will put them in if popular opinion says to do it. The B pillar bracing is something unique I came up with to still allow sufficient access to the rear seat. A normal X, \/, or /\ design just isn't going to cut it. This modified X design would spread the load over 4 tie in points via the bottom crossbar. The two outer tie ins would go to the frame and the middle two tie ins would just be bolted to the floor over the body mounts.
I could do away with the W bracing if not needed but the rest would stay since I need the diagonal braces for shock mount tabs and the cross bar for a shelf system for the rear cargo area. The upper cross bar in the D pillar pic would be the rear of the cargo shelf
I think this is my favorite view. With the tailgate up you are not going to see anything below the W bracing. The grayed out tubes are the C pillar bracing and shock mount tubes.
Here are some inspiration pics I have grabbed a few ideas from.
Love it good job, I'd say the only change I'd make is where your note is regarding the shock mount, I'd go straight down and continue that run vs \ this way.. Make sense otherwise I wouldn't change a thing.
Are you talking about coming straight down over the wheel well like that one inspiration pic? I could do that too but I think the sideways angle to the tie plate over the body mount is necessary and convenient since it will pass directly over the shock eye.
Let me grab another pic so you can see the right perspective. I may also just be not tracking with you 100%
This is what I am working with regarding the seat and shocks. Now those shock eyes will be 8-9" lower than they currently are once held down by shock tabs.
Lots of innovative ideas here. I really like the use of Schoenfelds...quality pieces!
Have you used that type of fuel filler before...I have one on a Jeep that blows ass, its difficult to get out most of the time. I also raised my tank into the floor, then found out it really hampers putting items in the back, so I raised the whole rear floor just above the top of the tank...gives a wide flat floor that way.
Nicely done, I love a build thread in progress.
No, I have not used that style filler before. I am going to put a utility shelf that will go over the cargo area at the height of the bed rails so I will be able to store stuff below the shelf on either side of the fuel cell and then over the whole cargo area on the second level with tie downs. I might try to make the shelf removable or adjustable if possible. If I had known they make filler neck adapters with a hose and cap I may have left the fuel cell completely under the bed but it's too late now and I think this is a pretty cool setup anyway. The only real hassle is that I will have to open the tailgate to fill up at the gas pump.
I appreciate your comments and input! Seems like I am talking to myself a lot in here.
Don't have a ton of time now, but want to earmark this build for later as it's the kids b-day and I'm cheating being on here. :D For sure want to check out your rear shock weatherproofing. I did the same thing on the rear of mine.
A quick look at the cage, and it looks like you might have some dead nodes going on? You need to get Eric in here to give it the once over.
Cool build. :waytogo:
Ok, there are at least a handful of you guys that care :waytogo:. I am not egotistic enough to really need the compliments but I do like feedback and interaction, just gets a little lonely in here sometimes :haha:
I was specifically trying to avoid dead nodes so if you see any point them out so I can rethink/rework things.
I don't have much to offer but I'm definitely watching, and I like what your doing. Nice work:waytogo:.
Hey TruckO
I have to drop my tailgate as well
My issue with that type of filler cap is the locking teeth dont seem to disengage the notches in the neck good and sometimes its a struggle, throw a little sand around and its even worse.
Mine is a summit unit
Hopefully yours is a better piece
So this just happened . . .
Ian and the film crew from Xtreme Offroad stopped by to help me recenter my 24 bolt paired H1s as part of their Driveway Rescue segment series. We got them all done and then they wound up surprising me with a set of 5 brand new recentered Trailworthy Fab 12 bolts H1s and 5 Pitbull Tire 41.5x13.5x16.5 Radial Rockers :eek1:
This has been long in the making. I first contacted Ian back in October and have been waiting for his schedule to free up. Lesson here, patience is a virtue. It has been super hard keeping my trap shut about this for so long.
If I can say anything about this experience it's that Ian and his film crew (Matt & Robert) are some of the BEST people I have ever met. Super friendly, down to earth, and generous as hell. Also, BIG shout out to Trailworthy Fab and Pitbull Tires for supporting this show and the offroad comunity at large!
Wow, saw the post on Instagram and thought it looked like this build. Awesome. Great to see Ian and crew out to help with the build.
That just happened huh?
Well dam the luck right?
Awesomerestness man!
Yeah, I was a bit blown away and these wheels and tires are extremely :pimp:. Definitely a motivator to get this thing finished ASAP, just wish my schedule allowed me to get out in the garage more often.
Anyway, here are some pics from filming in case you are like me and don't get on Instagram.
safe_image.php
safe_image.php
safe_image.php
safe_image.php
safe_image.php
safe_image.php
safe_image.php
