That's cool man I have been helping a buddy build up a bronco II similar year. Getting super duty axles , 60 and a 10.25 , right now
I don't know if I have ever seen the main tube on the bottom. Is there an advantage to doing it one way or the other?
Martin
, keep at itI have a Ruff Stuff one, and mine is the other way.
Martin
Nope, I've read enough other antiwrap threads. I am sure there is just as much debate about main tube on bottom or top as there is shackle in tension or compression. Obviously there are quite a few different ways to crack this nut but I still prefer the way I have done my two installations. To each their own . . .
I wasn't trying to argue the point that my way was better. I have no idea if it even makes a difference. I was just curious. I went back and looked through that thread, and found another one in there like yours. I had never noticed it that way before. You should add your pictures and information to that thread for future defense for others.
Martin
Are those monotubes?
Did you grind the frame plate yet for the draglink end?
And it's weird the end is on top, what pitman arm is that?
