Ok, ask for 9/16" fine thread flange bolts, 5" long. I need 6 of them. Flange nuts, too, if they have them. All in grade 8.
I've already been in the works with another member about this. Problem is, by the time the new sleeves get milled down, they're gonna be pretty damn thin. The o.d. of the sleeves I have here are 23/32". What do you think, too thin or not?
They skip the 9/16" also.Try this place. I have bought from them for years. They have tons of fasteners.
http://www.hillcofasteners.com/
For about the past month or so, I've been IM'ing with another member and we were making plans and details to have him get me some SS sleeves made for these bushings.That's not thick enough but if you had sleeves made that are .750" OD with a clearance hole for a .625" bolt that would be thick enough and then have them made from stainless steel. You might even be able to get those sleeves into the bushings without having to mess with the ID of the bushings.
I'm not against using regular bolts but flanged are my first preference.Oh Negative on that Ghost Rider. Sorry brother. called 4 of the big guys here. and it sure seems 9/16 in a flanged is not being made. one guy actually said 9/16 is like the redheaded step child.
Are you against a regular gr8 9/16ths unf bolt and flatwasher for some reason? that can be had much easier.
