Dual Tail Pipe Tips Placement GOT PICS???
foxman
Detroit MI
Alright guys, Just Got the Dual Mufflers and ordered the Headers, now All I gotta do is decide where I want the 3.5 in chrome echo cans to come out at. looking for Ideas. I do have Reese Hitch and 4" lift springs/Stock Bumper. I was looking to do something other than the standars straight out the back. Anything else look killer? Pic would be greatly appreciated (gotta know for sure before I have my guy bend/weld all the pipes).
Thanx
Jeremy
mine used to come out at 90s behind the rear wheels and point out the sides..i hated it, i cut it off and now i just have mufflers on the end of some pipe exiting under the bed until i can afford to have my 2.5" put on and dumps over the rear axle..
Here's how I have mine. (It's just the standard exit-out-the-back duals) /forums/images/graemlins/smirk.gif If I had to do it over again, I'd skip the chrome tips (they're rusting and look like crap) and exit out both sides just before the tires. Why before the tires? I live in Wisconsin, and having the pipes before the tires should lower the amount of salt (and mud when offroading) thrown on them.
For a unique, and cool, idea...search for the username Nofeartruckin00 - he's got single exhaust exiting out of the upper-rear corner of his driver's side rear wheel well. /forums/images/graemlins/pimp1.gif
Edit:
Here's the pic of Tony's (nofeartruckin00) setup.
I have mine out the sides behind the tire, I have only had it this way for about a month- a month and a halfBUt I like it. I can roll my back window down and not get gassed, My only compliant is I have to shut the truck off at drive throughs becuase it echos off the building.
i got mine comin out at a 45 in front of the tire
I got one comin out both sides
Here is a pic of mine.
It's run just like that on the other side. I had it run up high to get it out of the rocks. You could run it straight out instead of having the tips turned down. I used to run the exhaust out in front of the tires, but I had to get it re-run when I went to the bigger tires. Not to mention, it's a little quiter run out the back compared with it coming out right behind your ear.
BIGJ
k20...how close is that exhaust to the gas tank? i had a guy tell me he wouldnt do it because it would be too close to the tank like that...
theres about 2 1/2 to 3" clearance between the two, ive put my hand between the tank and the tip before and its not that hot honestly. If you get a competent pipe bender he can make it work. If my tips were a bit shorter i could have tucked them up and back some more, but as they are they are almost hitting my rear spring hangars. Its safe in my mind, if i had any doubts i would change it.
did a search in the member's rides for 'cheap chrome tips' and this came up /forums/images/graemlins/rotfl.gif
the pipes aren't crooked, it's the bumper
first image is what i have now
last image is what i did have
the last one...rear exiting rounded 2inch chrome tips...looks classy, not too showy, but they are out there...i didnt like them cause whenever i got something out of the back i got black rings on my pants
the side exits i have now, i like that cause flying by cars with glasspacks makes for some entertaining reactions /forums/images/graemlins/smile.gif
[ QUOTE ]
[/ QUOTE ]
Exactly why I wouldn't have it any other way. When I was in HS this was especially entertaining. I got the scumbag manager that fired me from my job at 0630 and 4,000 RPM in 2nd gear one day. It was GREAT!
Does anyone run dual aftermarket cats?
I have that pancake style and I had to re-route my crossover and I dont like it hanging down. I was thinking about running dual cats and dual mufflers and eliminate the front crossover.
can't get into your pics, (says forbidden) What do they look like?
Thanx.
Jeremy
Nice pics, I like...
I was thinking maybe strait out the back at an angle towards the ground, kind of looking like they are coming from up in the bed... anybody seen these?
thanks
Jeremy
Best thing to do that has a look like your describing is turn-downs. You can get chrome tips that are only a couple inches long, and they turn 90 degrees, so you can point them straight down.
Putting tips in the rear is a bad choice if you wheel a lot (another reason why I'd change mine to exit in front of the rear tires if I had the chance) because you'll eventually smash them. So, your idea of "coming out of the bed" could be cool, but not very practical. /forums/images/graemlins/smirk.gif
I have them dumped right behind the axle. This helps give it a deeper more agressive tone, especially with the 5" tips. /forums/images/graemlins/thumb.gif
