What's with the Edelbrock ad? Please get rid of that, it's obnoxious and everyone already knows you have a pro-flow system..no need to publicly suck Edlebrock's dick. :haha:
buwahaha riding that BroFlow
Seriously, I had to turn the fk’n sigs off today because it’s so annoying.
well then :flipoff11:mr. potty mouth grumpy pant . show me the rules about sig lines then . last i new it was ours to use . :deal: maybe ask me nice next time grumpy old man . :ignore: nice way to bring a guy down after a nice day . . . there is no need to talk to me in this nasty way or anyone else . show me a little respect please . you might be amazed how much i will do if you just ask and talk to me nice .
It was hard to be polite while being blinded by the Edlebrock sponsorship flag. Are they paying you?
The new one is still embarrassing, but at least the size is better. I can almost ignore it completely now.
Oh, and... :flipoff7:
That wasn't a sig line, that was a F-in billboard.
glad you got your junk running the way you wanted nonetheless...it's about time.
After the Hell he went through with Holley, let the man use the Edelbrock logo in his sig. Night and day difference with tech support alone.
Just dawned on me this morning that my old Samsung Note 5 had an older Edelbrock E-Tuner 4 software loaded on it. Version 4.0.0:2
Started the setup wizard and it loaded the map with no issues. So its definitely the newer 4.0.0:6 version causing the issue with setup wizard. I know there's a work around but wanted to report what I found.
wish they had a list of the old versions so i could have done this . i didnt think to save my old version or know how to on a tablet .
Unfortunately the Android system automatically updates programs unless you have that turned off in the settings or have no internet connection so for now, my older phone will stay off my wifi and is on airplane mode with BT enabled even though its not on Verizon network. There might be a way I can copy the older files and email them to you but I need to figure out where the files are stored and test it on my newer Note phone first so it doesn't mess yours up.
@sweetk30
I looked on my Android for the Edelbrock files and not seeing them yet. I may have to root the phone to get to the install file or edelbrock program. Maybe someone else may know where these files reside. If this was a windows laptop it would be super easy but the Android system hides its OS and apps unless you root the system.
no big deal . it runs for now . they will get us figured out with a update i am sure this coming week .
Thats why I was pinging Nate again. Anyone who buys a new system or updates their Android with latest version will not be able to do Setup Wizard which is almost a must to get the correct CID to display. I'm sure we're not the only ones. They have to be coming out with a fixed version in the next week or two.
What coil did you all use?
My original instructions say this:
IGNITION COIL
Edelbrock Pro Flo 4 EFI has an internal Coil Driver capable of direct firing an ignition coil. No CDI Box or external ignition devices are required. When choosing an Ignition Coil a primary resistance of .4 to 1.4 OHM’s is recommended. Exceeding this primary resistance range could cause internal damage to the ECU. Edelbrock recommends Max Fire Coil part #22741 or #22740. If running a CDI box there are no limitations to coil specification.
Last page shows Rev 4/24/18
SO I purchased Max Fire Coil part # 22740 when putting the engine together.
I happen to notice the coils listed in latest instructions contradicts the info above:
IGNITION COIL
The Pro Flo 4 EFI system has an internal coil driver capable of direct firing an inductive ignition coil. An inductive coil alone will support most applications without the need of a CDI box. Edelbrock ignition coil part #22746 is recommended. The following is a list of alternative coils that have been validated by Edelbrock to work well with the Pro Flo 4 system:
MSD Blaster 2 #8202
MSD Street Fire #5524
Pertronix Flame-Thrower #40111
Bosch "Blue Coil" #9220081083
Jegs High Energy Ignition Coil #40105
Summit Racing High Output Coil #G5215
Summit Racing High Output Coil #G5219
If not using a coil from this list, ensure that the coil’s primary resistance is at least 0.6 Ohms and inductance is at least 6.0mH. Pro Flo 4 can NOT directly fire low resistance, low inductance coils that are intended for use with a CDI box otherwise severe damage may result. If choosing to use a CDI type coil, a CDI box must also be used. Damage caused by improper coil selection is not covered under warranty. A CDI box is recommended for high horsepower and high rpm (>6,500 rpm) engines.
Note that Edelbrock ignition coils part #22740, #22741 & #22742 are intended for use with the Edelbrock Max-Fire distributors only and are NOT compatible with the Pro Flo 4. Using these coils with the Pro Flo 4 may damage the system.
Edelbrock 22746 canister coil: https://www.edelbrock.com/shop/ignition.html
Example of an UNACCEPTABLE coil that will damage your Pro Flo 4 ECU is the MSD 8207 Blaster SS coil: https://www.holley.com/products/igni...ils/parts/8207 Its primary resistance is 0.355 ohms and is below the minimum primary resistance spec.
______________________________________________
Looks like I need ANOTHER coil now. I wanted to bring this up to others in case anyone else bought the same coil last year. Also can't seem to find coil 22746. Checked both Jegs, Summit, Edelbrock.
