I realize If the engine is mostly stock then no need for high volume pump.
:raises hand: Plus I need two (trail spare) so that's extra cash I can use elsewhere.
I had a 255 in the 87 K5 stock tank I did YEARS ago. Its a very easy swap, same dimensions as stock pump. Even my wire harness matched the stock. 450 LPH is a different story which I wrote about in my build.I know the easy reason the 381 gets used is that it is a drop in for the tbi style sending unit
You able to drop in a larger pump, or I should say “what does that entail”?
$30 extra? Hell a dinner cost that!:raises hand: Plus I need two (trail spare) so that's extra cash I can use elsewhere.
You can always use the old stock pump as a spare to get you home or buy a spare EP381 just for temp use. Many sell a used 255 pump cheap. Like 20 bucks since they upgrade to something bigger. I have two spares as of now.$30 extra? Hell a dinner cost that!You can always use the old stock pump as a spare to get you home or buy a spare EP381 just for temp use. Many sell a used 255 pump cheap. Like 20 bucks since they upgrade to something bigger. I have two spares as of now.
They're only $70? I remember them being over a $100 a piece.
Actually.... $52! Just found this. Looks like its coming straight from Walbro so I don't think it would be a fake but I'd double check.
https://www.amazon.com/Walbro-GSS342-Fuel-Pump/dp/B000EVN7W8
I was reading that the other day. Also GM is rating that at 425. Margin of error...@Bent77 zz6 EFI is the same as PF4 IIRC
quote-
Fuel Pump: The ZZ6 EFI requires the a fuel pump capable of a minimum flow of 57 GPH (215 LPH) at 58 PSI.
In a round about way yep.
They are basically stock 8.1's. Other than the tune. Having witnessed him pulling away from me on every mountain pass I can attest that the 381 pump is more than keeping up with the 8.1's demands.A stock 8.1 is 330hp at crank so it might be ok for that but why take a chance on a smaller pump and have a possible lean condition? If the 8.1 is modified with higher flowing heads and larger TB then I'd suggest against it. You always want to run a bigger pump than you anticipate HP wise.
27 gallons per hour is only 102 LPH. I think its at least 155 LPHI found one other site beside rockauto stating the ep381 was 27 Gallons per hour:
https://www.rockauto.com/en/moreinfo.php?pk=90717&jsn=3
Agree. Should be fine for a stock 8.1. Anything more than than that will need something larger. A 255 is almost plug and play especially with the correct harness adapter.In a round about way yep.
Modification would certainly put it into the need for more pump. And at least as far as the spec is for the 8.1 for fuel pressure, the 381 does have the same ability as the later pumps that came in the gmt800 trucks with the 8.1 originally. Still don't know what the lph rating is, but it works for that application.
For most 350ish engines with stock or even Vortec heads, the 381 should be fine. You're probably not over 300-350hp at crank. On the other hand if you slap some high flowing alum AFR heads on and a decent cam, then you are looking to be closer to 400hp at the crank and the 381 pump would not provide enough. or you will be close to the limitations.So all of this confirms that my little 354 small block is just fine with the 381 pump. I just have to confirm this by watching the fuel pressure.
@mrk5 , I didn't have to add a pressure gauge to my Broflo..
I would think you are well over 350hp with those heads. Edelbrock heads flow pretty good and have used them in the past on a 496 build. One option is to look at Edelbrock crate engines with similar heads and cam profile. Even a non roller cam can easily make 400+hp like this one below.
