Edelbrock Proflo 4
Discussion in 'The Injection Section' started by 6872xtc, Nov 19, 2018.
  1. nmxhustla
    nmxhustla Registered Member Premium Member
    Feb 5, 2019
    46
    33
    jacksonville NC
    Build(s):
    Recently installed this setup in my 1991 blazer with a 454 swap. Plug and play super easy install. Just needed a better fuel pump. Also wtf why didn't they include spark plug wires and coil? It wouldn't have killed em
    Big Ray and Kain like this.
  2. nmxhustla
    Feb 5, 2019
    46
    33
    jacksonville NC
    Build(s):
    Kain likes this.
  3. 6872xtc
    6872xtc make mine modified Premium Member GMOTM Winner
    Sep 16, 2008
    5,039
    4,317
    Palisade,Colorado
    Build(s):
    I see that you found this thread, I probably wouldn't know how to post a link for you anyway!
    :rotfl:
  4. nmxhustla
    Feb 5, 2019
    46
    33
    jacksonville NC
    Build(s):
    Haha yeah I figured it out, this site just needs a search bar☝
  5. Bent77
    Bent77 lil meanie Staff Member Moderator GMOTM Winner
    Dec 3, 2002
    24,703
    29,942
    colorado
    Build(s):
    Using a phone?
    The magnifying glass at the top it the search button
  6. nmxhustla
    Feb 5, 2019
    46
    33
    jacksonville NC
    Build(s):
    Shitt I didn't even see that, yeah im using a phone
  7. Bent77
    Dec 3, 2002
    24,703
    29,942
    colorado
    Build(s):
    I knew this lol
  8. Shawn
    Shawn Nuckin Futz! Premium Member GMOTM Winner Author
    2,276
    734
    5280'
    Build(s):
    3
    A true Walbro 255 pump is $52 now (from Walbro) and can feed 500-550hp safely. If you need more pump then go with the Walbro 450. It requires slight modification but still easy to install. You'll need to use a relay with either one if its in the tank. For a coil, stick with the MSD Blaster 2 or Blaster 3. Make sure to download the latest instructions since they have changed and the coil info in the old instructions is WRONG along with updated FP relay wiring diagram.
    https://www.amazon.com/Walbro-GSS34...61&imprToken=aS5TFiypYCHq2qlDa0Kc.w&slotNum=0
    Don't forget the install kit which is like $11
    Latest Version of instructions here. 3 sticky threads at the top.
    https://forums.edelbrock.com/forum/pro-flo-efi/pro-flo-4
    Direct Links to instructions-
    https://edelbrock-instructions-v1.s3.amazonaws.com/edelbrock/35760.pdf
    https://misc.edelbrock.com/forum/PF4-Distributor-Install.pdf
    https://forums.edelbrock.com/forum/...5-pro-flo-4-ignition-coil-fuel-pump-selection
    tRustyK5 likes this.
  9. wheels87k5
    wheels87k5 24 Karat Premium Member GMOTM Winner
    May 1, 2007
    1,639
    1,249
    Goddard, Ks
    Build(s):
    @Shawn
    I bought the Walbro-GSS342 on Amazon for $52.81. Came in an unsealed bag with mineral spirits. Awesome. Where do you get the install kit for $11.00? It's going in the 87 K5 tank.
    Is the relay the one used on the TBI units that mount on the firewall or are you talking about a different relay?
  10. Bent77
    Dec 3, 2002
    24,703
    29,942
    colorado
    Build(s):
    I think @6872xtc used the TBi one
    I used the $10 special from vato zone
  11. wheels87k5
    May 1, 2007
    1,639
    1,249
    Goddard, Ks
    Build(s):
  12. 6872xtc
    Sep 16, 2008
    5,039
    4,317
    Palisade,Colorado
    Build(s):
    Yes, I used the TBI relay since it was already wired back to the tank. This also made it possible for the Proflo ECM to control the ground since the pump is grounded in the '90 TBI tank.
  13. Shawn
    2,276
    734
    5280'
    Build(s):
    3
    Yep you found the install kit. I did my own custom relay in the back and used the diagram off the install instructions. The ECU ground wire triggers my relay. They said you must use a relay if its in the tank.
    wheels87k5 likes this.
  14. sweetk30
    sweetk30 selective wrench turner guy Premium Member
    Nov 1, 2004
    31,706
    6,711
    horseheads , ny 14845
    Build(s):
    4
    warm day out . time to install the sticker .
    mrk5, Shawn and Big Ray like this.
  15. sweetk30
    Nov 1, 2004
    31,706
    6,711
    Build(s):
    4
    so on a NON pro flo 4 related call to edelbrock tech today we got on the efi subject and how happy i was with my pro flo 4 over the holley sniper unit . he said the last few weeks they get 4-5 calls a week on them and can you help me tune it and figure it out and they have to tell them sorry we are EDELBROCK not HOLLEY :doah:
    i guess the snipers have been having a lot more problems but i dont watch the info boards on them anymore .
    and the tech guy said the reason they stopped the carb replacement efi type units was to many problems and to much bad they just couldn't fix so they stopped the production / parts and focused on the full efi stuff and its been doing so much better for them .
    my unit is still doing great and good mpg over the sniper and purring great . flagwaver
    Big Ray, wheels87k5 and nmxhustla like this.
  16. nmxhustla
    Feb 5, 2019
    46
    33
    jacksonville NC
    Build(s):
    I gotta agree with you, my pro flo is pretty legit so far. Only issue I've had was too much fuel and I called edelbrock and they walked me through resetting the fuel trim. Easy fix an fast service
  17. sweetk30
    Nov 1, 2004
    31,706
    6,711
    Build(s):
    4
  18. Shawn
    2,276
    734
    5280'
    Build(s):
    3
    SWEET!!!! Did they mention this on the forums yet? Where did you see this?
  19. sweetk30
    Nov 1, 2004
    31,706
    6,711
    Build(s):
    4
    nate s talked real breefly in a thread and someone else posted this ad on there in a thread .
    i knew you would be all over this . :saweet:
    there is a guy over there doing E85 and 80 lb injectors and 525 lph walboro pump on his own . nate s said there about ready with the boost update to add the same injectors the guys is using on there update list of options . 60 lb units now can do around 725hp if i recall . the 80 lb units will be near 900-950 hp i think they said with reg gas .
  20. Shawn
    2,276
    734
    5280'
    Build(s):
    3
    Good to hear. I saw that e85 thread. I wouldn't mind being able to run e85. It's much cheaper than higher octane pump gas but it normally requires a custom tune and starting tables. When I was going to run the turbos on the K5 I went a little extreme and got 240 lb injectors before I went to the PF4 system. They actually idle really nice when I ran them on my old race car. Looking forward to the new system.
