pma4x4
AKA Yankeeroad
I swapped the fuel inlet to the back. Pretty easy. The crossover tube is a bitch to put on the front since the intake sits higher there. So I put the tube on upside down to get the fittings on so the middle part is now taller than each fuel rail. Then I forced it down and it now contours the intake. It does touch the intake but I could put a piece of rubber tube in the center just to keep it off the intake.
The Edelbrock rail fittings are -6AN O-ring. I'm removing the plug at the end of one rail and have both fuel rails go to the Aeromotive FPR and have my fuel line go into the FPR well so the rails, and fuel source all go into one point. The fuel pressure sensor will also be in my FPR. Its costing me a crap load of AN fittings and braided hose but it will look decent when done. Already have the FPR from previous 9 second car. Honestly I'd rather have the fuel line from the pump go through each rail then into the FPR but its too many fuel lines going across the engine.
You got a build thread on this with some pics?
