Well for example, the GM crate engine is the ZZ6 EFI, and is the unit that the factory has the PF4 installed with. The map 5008 is designed w/ and for that exact application
I have a SP350/385 crate with a PF4 installed. It is part for part identical with the ZZ6 EFI, other than the tuning being locked out (per GM and Edelbrock)
Trying to find what exactly they preset as the parameters for that has felt like I’m asking for the logic basis of the programming, some dark secret proprietary list that shall not be spoken of
All I was hoping for was the list of stuff like @mrk5 has at the top of the forum for the original map 5008, since it is essentially what I should be using
I feel like I am missing something I didn't see, is there a reason we can't just select tune 5008 and look at those parameters on any unlocked ECU?
