Dabba
Okay, so the last two times i went out wheeling on my stock truck, i beat on her pretty hard. Really hard in fact. Now ive always had a problem, which i thought was the front bumper being loose, even though i took it apart and put it back together myself, but tonight my friend pointed out my body on the truck is loose. After wheeling really hard on it, im noticing bad squeaking from the front end on bumps. I think i killed the front body mount(s). How exactly do i check them? I mean where are they and how does one fix them. Is it possible the trucks screwed if my mounts are busted?
Secondly, im having a slight problem with my tranny shifter. It seems that when i shift it to park now, it just barley makes it into park, dosnt totally lock in. Tonight i started it and it just started moving backward, which means it was in reverse, and it also means the neutral saftey is broke'd. I dont care much about the neutral saftey switch but any way to adjust this easily?
Thirdly and finally, i bottomed out tonight and the only damage is my crossbar that protected the t-case.. ITs kinda bent down backwards a bit. It is just for protecting the tcase or does it have a integrity purpose? Would it be wise to replace it or should i leave it as is. Im pretty sure the hard wheeling days of the truck are over as i feel she cant really take it anymore. Not until a find a military one ton at least. Ill be consulting my haynes manual but any knowlage you guys can share would be great. Thanks.
