I was just thinking it would be sweet to put a float switch in series with the fan control relays. You could probably cut up a junkyard washer fluid tank to get one. Mount it under the rad support so as water gets up close to the fans they turn off. Then once you climb out of the water they would kick back in.
I've never checked, but I bet there's a more high tech way of detecting water using an electrical sensor. Just need to make sure it doesn't trigger in the rain. It's a cool idea either way.
