I got those mufflers put on tonight. Even still dumped they are vastly quieter than the bullet mufflers I had on. I’ve got before and after videos I’ll post in the morning.
Well in some people's eyes that is not a negativeBy far the best thing I’ve done on this truck is the ORD springs. I had factory springs that had been re-arched and some big ass blocks in the rear when I bought the truck. It was terrifying trying to rock crawl because nothing flexed or moved. Got the ORD’s with their custom bilstein’s and it rides smoother than my wife’s 2020 Silverado 1500. Doesn’t get upset over bumps or bounce. Soaks up speed bumps and irregularities. It does lean more in turns but I’m not running sway bars either. Greatest thing is when I’m crawling the suspension is actually moving and has dramatically increased not only my confidence but the trucks abilities as well. One thing I will say that’s a negative is they didn’t settle at all. I was hoping they’d drop an inch or so after some use but they are still at the exact ride height even after 3-4 crawling trips. I ordered 4” lift springs and they sat at the exact height of my 6” springs I pulled off. So either the 6” springs were sagged really bad or these don’t settle. Another member on here @84k5oleyeller experienced the same thing with his. But that is the only negative thing I’ve got to say about them. Everything else is a positive.
What I mean is if I buy a 4" lift, I expect a 4" lift, and if it settled to 3" after a few trail runs I would be disappointed.Good for them. For me it is.
I bought a 4” lift and it’s sitting at the same height as the previous 6” lift. There has been no settling on my springs. Disappointing? No. Unexpected? Yes.What I mean is if I buy a 4" lift, I expect a 4" lift, and if it settled to 3" after a few trail runs I would be disappointed.
Now if you are saying you got a 4" and you got 5" of lift and expected it to settle to 4" and it didn't then I can understand your position
Just as I thought.I bought a 4” lift and it’s sitting at the same height as the previous 6” lift. There has been no settling on my springs. Disappointing? No. Unexpected? Yes.
The bottom of garage door. Problem solved. Or just air down and air back up each time you pull in/out of garage
