Exhaust ideas
I run cat only on my crew cab. Sound fine, pretty quiet actually.
Anyone recommend a good aftermarket cat for a decent price? My K5 needs redone to make room for an antiwrap bar. I want to do single exhaust with a side dump and a cat. Guys aren't kidding when they say duals out the back swirl the exhaust right back inside.
Anecdotally I've heard the aftermarket converters are cheaply made. Not sure it's true, but don't have much choice AFAIK.
Based on their response to my inquiry regarding how to determine correct placement, I appreciated Magnaflow getting back to me with the data I needed:
"Desired 'light off' temperature is 400°C (750F). This remains pretty constant throughout all converter applications and refers to the temperature of the gas as it flows through the center of the converter. Typically we will measure 250 – 350F on the inlet pipe not the converter body."
I expect to go with them when I go to buy one.
I agree, I like single 3". On a mild 350 I do 2.25" into single 3". Sounds good and saves you from having to buy 2 mufflers and associated pipe.
If you want quiet, get a 20"+ magnaflow muffler. If you want some rumble, use Thrush full welded muffler. The Thrush muffler is less than $40 on Amazon.
When you run this does the single exit driver side?
Do you have a picture I'm getting my exhaust redone to stock manifolds , removing headers and want a single 3" exhaust but I forget how stock looks under the truck.
I'm also bringing my Tcase back up to stock and not dropped 1".
One of the next projects for me is new exhaust so I thought I'd ask the experts..
I want dual exhaust (either straight back or 90 degrees on each side), for it to sound good (kinda loud but ok for a 60mph 1.5hr ride), and I'll say a good value (inexpensive but I am willing to pay more if its really worth it). And this will be on a 85 full convertible (with softtopper if that matters)
Thoughts on: Size (thinking 3"), DIY, custom shop, Muffler man special, and had one guy tell me to just cut the cat off and keep the stock mufflers...
Thanks!
Definitely love my 3 inch from the headers with cross over, then out the body.
i have hedman longtube headers now and want them off. I don't think they're really needed for a more or less stock 350. My truck sounds good.
I'm thinking these manifolds and keeping my thrush weld mufflers. I'm just torn on going into a single exit on the driver side. I already have the two mufflers and would hate to waste one.
I could do an Hpipe after the Tcase or something or just sell one and run the exhaust how it was stock but with 2.5 to 3" single
just an fyi, 87-91 came with single 3” exhaust, though not mandrel bent. Should be a bolt on upgrade (without the pancake cat of course).
Tie in ypipe to factory cat location, and then source factory at auto parts store. Use to be cheap, who know what it costs now
I just finished my exhaust. Long tube headers, 2.5" Stainless tube, Cheap Jeg's FlowMaster knock offs. I turned the exhaust down right at the rear axle due to weather. Its loud but not unbearable. My 383ci SBC is healthy engine. I guess I will get to see what the neighbors think when I start driving it to work leaving the house at 5am.
@TJ1978 keep the duals, do the cross over. My reasoning for a single is I have electric fuel pump in rear right and big remote trans cooler rear right, don't want muffler heat on those.
Copy that... hooker manifolds cross over where after the Tcase before rear axle?
I built my exhaust so it's not factory. With the fat block I did 2-1/2" dual into 3-1/2" single.
I end up with driver side exit because of the passenger drop tcase.
Thinking these, I'm over the hedman headers. In the way and not really necessary.
My plan,
Raise 203 Tcase back up to stock position (eventually then ORD motor mounts installed). So, have the exhaust run high enough to allow that 203 to be raised up.. Cross over after Tcase, keep my thrush weld mufflers, the exit past rear tires out the side.
Can't raise it back up with this set up.
I'm thinking these. Are stock manifolds the same size 2 1/2, as these offered by speedway? I way better able to find used ones and save some $$
With the headers I have it's pain in the butt to mess with. The collectors are in a junk spot making getting the collector flange off a pain. Also I have to remove the passenger side collectors flange in order to remove the torque converter cover. Also these headmen header bolts are lame and another pain to deal with.
Thoughts?
Glad this thread started. I just got my Stainless Hedman Hedders. Planning my exhaust for the 496ci build. Thinking 3" Stainless Duals only because of the HP the engine may have. Hard to find a shop to do it. Anyone w experience with a shop in the PA, NJ or DE area. Hoping they can do purge welding. Any experience with purge welding?
Any good photos out there for pipe routing?? Even for the SB engines the routing can make the difference...
My 2 cents, purge on stainless is the proper way. Its 100% needed in an intake because you could get boogers inside the pipe that would find their way into the engine or a turbo. On an exhaust it really doesn't matter if some crusty boogers come loose, its after the engine and will get blown out the back.
