Few portland trucks i like.
My '82 K2500 was the first truck I have owned that had dual tanks...probably a rare option for an 8 foot stepside diesel pickup!..bet the thing would go 1000 miles if you filled both 20 gallon tanks when it was new...(it only has one tank now,and it weeps,and the sending unit is junk :doah:)...
You dont see dual tanks often around here,only on dually's and crew cabs mostly,and on Fords!..
That's so strange to me. I would say at least 75% of these trucks out here are dual tank. Between me and my friends and family I can think of about 15 of these trucks. Only one had a single tank out of that bunch and it was a 80 k20.
Probably the fact here you can go from one end of MA to the other in 2-3 hours,or nearly to the border of Canada and to NYC in about 4 hours--a "tank away"...mostly larger trucks that people bought to haul trailers or slide in campers came with the towing package are the ones that included the dual tank option...
Out west in and in the plains,you can drive a long ways before you see another gas station,towns are further apart,more rural,so you need the extra gas!..
Yeah,it weeps some right at the inside seam where the strap goes--it's partly my fault for not installing it right away,I let several months pass before I got it in the truck--it did look dam good inside & out too,I painted it nice too,and was not expecting any problems...if I thought it was going to leak I wouldn't have used it..
It's not your fault,and I appreciate you giving it to me AND delivering it!--no need to apologize!..it's still in the truck and seems to not drip lately,I haven't filled it over 1/2 full though either...just my crap luck..maybe the strap tweaked the seam when I installed it?..:dunno:
I have to take it back out again someday probably,the stupid diesel sending unit I transfered into it from the original tank was junk,now the fuel gauge buries at 3 o'clock...
I was able to unplug the sender wires, and plug the one that was on the passenger side tank I "deleted" into the wires, and the gauge does work,so its the sending unit that's dead for sure..I should have checked the gauge first,I could have used the original RH sending unit on the drivers side had I known that!.:doah:..
Not sure if I'll even have the truck on the road much longer,the long list of "defects" on it keeps growing,so it may end up just being a "yard truck"...
The cab and inner fenders are getting pretty rotten,and that discourages me from fixing its many other sins that could "finish it off" in short order...now I'm dealing with tranny shifting issues thanks to a dead vacuum pump,the oil pan is still dripping due to rot, and I've been filling the crankcase with used oil,so it could decide to toss a rod or spin a bearing,so I'm not willing to spend much on it as far as money and labor now..
This is interesting. One more thing to think about when buying trucks.
1000 miles is my goal for Big Blue. I went ~850 miles on our Lake Superior circle tour (which got us through Canada without having to purchase expensive fuel :D), but I didn't carry an extra gas can, so I wasn't willing to get the second tank too close to empty (we were heading through some rather deserted sections of da U. P. when we started getting low). Not to mention that I hadn't installed the electric priming pump yet.
My mileage is slightly higher now, and I'm able to prime more easily, so I'm thinking I'll run it dry and see how far it gets. :popcorn:
