No it will not rub the cover.
.readymix said:New question...
What are the best valve cover gaskets to use?
Rubber or Cork?
readymix said:I got the Cloyes C3023SXP HD double Roller. Paid $24 at O'Reilly Auto Parts.
And yes I did crack a rib during the season.....and yes the LSUG's were there when it happened.....but no it was not anything out of line.
I know part of the oil leak was from the timing seal, the rest of it I am not sure about. It could be from the valve covers, intake or rear main seal.
I pulled the valve covers, and I think the passenger side was leaking. I'll get that ixed up. If it is the intake I might do it, but if it is the rear main.....I will just add oil.
.sandawgk5 said:You dont wanna pull your 465 with a cracked rib to change the rear main out?![]()
I hate chasing oil leaks. I am still trying to find the one from my PS system.Dik
readymix said:I need new hardware for the valve covers anyway. The stupid torx bit stripped 6 out of 8 bolts out.
I have never seen studs...I was going to just use some bolts. I'll check the local parts houses.
Mine uses bolts
