Well I have gotten a little done, but exams, the gf, and having two litters of pups is slowly whittling away at truck time. Since my last post, I have converted the doors to power windows/locks, installed keyless entry, and ripped out the interior harness and rewired the whole thing. I have also gotten some more goodies that will be put on the instal list with everything else. A few things like a set of h2's, a set of used 37" bfg mt, 700r4 which is going to be rebuilt over the christmas break. My list of to-do's is as follows
(Before Thanksgiving)
1)Paint interior some shade of darkish green, most likely forrest or OD
2)Put all the interior back in the truck.
3)Paint exterior/bedliner for bed
4)install rear sub tank, with braided line, remove mech fuel pump, install tank switch, wire up electric fuel pumps, fab 2 crossmembers for mounting the rear tank.
5)install the instant heat glow plugs I ordered a month ago from ss diesel supply, and wire up ford starter selenoids for the starter and glow plugs.
**The following list is a list I want to finish by the end of my Christmas holiday, which ends the 16th of January when classes begin.
1) Install 6" front lift springs, rear shackle flip, brakelines, and shocks.
2) Clean up and flush the axles, maybe replace pads and rotors.
3) Fab a panhard bar for the front, ditch swaybar, inboard rear shocks, ford shock towers for the front, fab an overkill steering brace to keep the frame happy, fab new spring perches.
4) Mount h2s on 37s and install
At this point I am up in the air, I would like to mate an np205 up to the 700r4 I am rebuilding, but already have a low mileage np208 that is free. On one side I can pb keep the rear driveshaft and mod the front since the 700r4 is several inches longer than the th400 in it so it will help compensate for the lift. The other, I would have to rebuild the np205, and have both of my driveshafts modded...equals more money...hmm.
5) rebuild and install 700r4 either with stock np208, or a rebuilt np205.
6) reinstall driveshafts.
7) maybe install an onboard air setup and get a/c system put together
pb wont get to the a/c til spring though since the winters here make it unneccesary to have a/c.
That is the list as it sits now pinned to my wall, so hopefully this thread will start to get updated more with progress I have made, and lots of pics.
Regards,
Remington
