S
o it does tilt rearward. It also has ports on both sides of the piston that are capped/plugged and I suspect a small amount of air can be trapped there as well I’ll have to pull it and bench it again Each caliper has upper and lower bleed screws. It’s Al’s been recommended that I tap the calipers to shake loose any trapped airIs the master cylinder level or does it have slight tilt from front down to towards fire wall ? If it does there can be air trapped in front of the front piston. Removing and bench bleeding will solve this. How many caliper bleed screws, does ea caliper have ?
