For sale 1984 Chevy K5 Silverado Blazer
With 1988 350 EFI engine, 700R4 trans, 208 transfer case, 373 gears. 33X12.5 R15 LTs, cruise control and air conditioning doesn't work. 4" lift. List of items that have been replaced in the last year, battery, alternator, radiator, water pump, belts, hoses, heater core, spark plugs, wires and cap, fuel pump and sending unit, transmission flush and filter, U-joints in front axle shafts, front and rear drive shafts, front drive shaft CV joint, seals and bearings in front axle, brake hoses, calipers, pads, rear break shoes, hardware, wheel cylinders and axle seals, front and rear axle axle lube with lubelocker gaskets, transmission, transfer case had open inspection and new seals, Bilstein shocks. Comes with full size spare.
$13,000 SOLD!
