Fly Fly Flywheel don't fit!~
noahrob
Author
Santa Barbara
Ok, Here is the deal, I am putting a TPI 350 (1987 Formula) into my 73 blazer which had a carbed 383...I run a SM465 mated to a 205. I put in the pilot bushing and was about to put the flywheel where the flex plate was when bam, the bolt holes don't line up on the crank. My flywheel has a center hole of 2.5 inches and the crank on the new engine wants 2 inches. The flywheel and flexplate are both 14 inches in diameter (and I run a 12 clutch) so I am confused...Is this simply the difference between 153 tooth and 168 tooth flywheels?
Anybody got a bead on the correct flywheel...
Shame on me.. .I think the answer is that in 1985 or 1986, chevy changed the bolt pattern and since I am going frmm a 1973 block to a 1987 block wham...I need a new flywheel. What do you think...?
Yep, you figured it out. When GM changed to the 1 piece rear main seal starting in 1986 the bolt circle changed as well.
Damn you GM engineer geeks!!!
Hmm...anybody know where to buy the new flywheel for cheap?
Anybody need a good flywheel for ht etwo piece main engines or a flexplate for the new one piece main?
Well, you wouldn't have been able to use the flywheel anyhow as a 383 is externally balanced and is different than the external balance of the later style 350's with the 1 piece rear main.
Here is the GM part number for a flywheel with a 1 piece rear main seal engine. 10105832
Summit Racing #RAM-1530 = 269.95 for a steel flywheel or RAM-2530 = 429.95 for an aluminum flywheel
Hey, Thanks man...I looked up the part number and it seems it is a 12" flywheel...I am currently running a 14" er, but I will check out summit and jegs. Thanks again...
I found it on the internet on som esite, but now I can't remember where...I was able to find the part on Summit and SPDC, but am not sure of the difference...it almost looks like the 10105832 is the steel version and the 14088648 is cast iron?
Anyway, I think I want the 10105832...although the other one is much cheaper.
Now I remember, I couldn't find 10105832 at Jegs or Summit and somehow through an application search, I found 14088648
