Ok Scott, you got me. I want a BBC now. I hope your happy.
The deal is, I also want a production class EFI system. I do like the Ram Jet system, but the Ram Jet 502 is $10k.
I wouldn't mind spending money, but that just seems way too much for what it is.
However, GMPP did make an all alum ZL1 RamJet 454 and tuned the controller for the 454. It was a limited prod. run (200 I think), and was stupidly priced (came in around 20k
, actually here's one on eBay now!)
Using the parts list from that engine, it's the same RamJet 502 system, just a different part number for the computer, which I've already looked up and you could buy from GM separate. The RamJet complete system is also available from GM by itself, complete with harness, injectors manifold/rails...etc)
WIth that, one could conceivably purchase an old tired production 454 block (they are around here for as little as $100), with machine work, and adhering to the specs of the cam and heads for the ZL454 they built, so the RamJet tuning would work right, one could conceivable build a nice Ram Jet 454 for, I price around $6800. That's with alum heads, 4340 forged crank and pistons. A wee bit cheaper if one used iron heads. That's only about $1200k more than the RamJet 350. Of course, if one wants to compare apples to apples, I could get a tired old 350 block for near nothing and build it cheaper than the GMPP ramjet 350 price.
For those that may be wondering, I've thoroughly researched various EFI systems. I won't run a carb, the ones available today just aren't up to the job of daily use in cold, salt, snow, heat these days, IMHO. And the Holly and Accell EFI system, you have to tune yourself, which I think won't come out much better than tuning a carb. I like the GM system as I know they've put over 1800 hours of tuning into that system and that's after it was initially developed for boats, and those are trained GM engineers, the attention to making it work right in cold, high altitude, heat, humidity, smooth idle. Not to mention weather, vibrations and other little things. Just my opinion, and that's what I want.
Oh, the K5's got SM465/205 with 14bff rear and Dana44 front. So the drivetrain is ok to take it I believe. I havn't bought d-shafts yet, they'll be on the way.
Anyway, the question is, money aside, is BBC worth it in a K5? I will tow some, a 4 place enclosed snowmobile trailer, but my K5 with the factory tired 350 never seemed to mind that trailer, and we usually only take 2 trips a year and I don't always drive. Medium trail use (not much rocks here in MI).
So for those that have had or have a nice 350 vs. a BBC, is the BBC really worth it or necessary in a K5?
I was set on the SBC, but several people I know, and some more thorough reading here is making me want a BBC now. I can't imagine why? The thinking was since I've put so much into my K5 thus far, it is my 'dream truck' after all, the best of the best, so why not a BBC.
I know the standard response will be, well, if you can, go for the BBC. I just kinda wonder from people that have had both in a trail/DD rig, what their thoughts are. Is it really that much better.
I wouldn't mind spending money, but that just seems way too much for what it is. However, GMPP did make an all alum ZL1 RamJet 454 and tuned the controller for the 454. It was a limited prod. run (200 I think), and was stupidly priced (came in around 20k
, actually here's one on eBay now!)Using the parts list from that engine, it's the same RamJet 502 system, just a different part number for the computer, which I've already looked up and you could buy from GM separate. The RamJet complete system is also available from GM by itself, complete with harness, injectors manifold/rails...etc)
Sure, stroked small blocks can make the same numbers. But those numbers are made at a lot higher rpm than a BB makes them. I wont even go into fuel economy. BBC will always get less than SBC. It takes fuel and air to make power. The more displacement you have, the more fuel and air you can cram in a cylinder, the more power you'll have on tap. Its as simple as that. Doesn't mean you shouldn't aim for the best bang for your buck though either! I think there can be a compromise!
