84CUCV
3/4 ton status
i cant even think how you would put a 241 and a 205 together???
(cough Atlas cough)You use an adapter kit like you do with a 203/205 setup. Basically you hack off the back half of a 241 and weld on a new aluminum adapter plate to the back of the 241. Then you bolt the 205 to the 241 with a new intermediate shaft. Same idea as the other doublers except you cant unbolt the 241 range box, you have to cut it off and have an adapter tig welded to the case half.
Harley
you would need to cut the floor right?? for that
the exhaust is the problem. I have mine run between the floor and the t-case. some people have managed to squeeze it inside the frame rail, but the fuel and brake lines are right there.Atlas has many options for gearing, and they have the 4 speed. As for price, I dont think its that big of a difference when it comes down to a few hundred bucks.
Back to fixing the driveline problem![]()
do you have true duals?
so the D D kit can be used for the 241 and 205? just want make sure i got this right
yes.
