Adventurous 4x4
here you go. Should be pretty easy to figure out from the picture. It is a 90 K5.
Haven't gotten the frame you're working on fitted yet. Can you make up a template?
No, my frame is all bent up underneith. I was going to use the boxing kit to fix it. If I make a template it might not fit other rigs.
Any luck?
You still offering this kit Kurt?
. I'll be ordering a kit from you in a month or so.Didn't see it on your website, but any plans to do a 1-ton? I've been going back and forth. Major frame flex when wheeling and pulling combined with midwest salt completely killed the cab on my old K20. The K30 is way stiffer but I've still considered boxing it. The body is straight and almost perfect and I'd like to keep it that way.
BTW, '78 K30 longbed, regular cab.
